Re: Water in Oil
Posted by Rich Cota on July 24, 2000 at 10:45:52 from (198.56.12.237):
In Reply to: Water in Oil posted by Andy on July 24, 2000 at 05:33:24:
Andy, I would tend to suspect a cracked head. If it runs fine when cold but looses power and or misses after it gets warmed up it could be a bad coil. But if you're getting water in the oil then you may have a crack in the head that opens up after it gets hot and lets water into the cylinder.90% of the M's that I overhaul have cracked heads. They have been heated up and cooled down so many times that the metal is failing.
Post A Followup
: Re: Re: Water in Oil
