Re: digital tach again
Posted by Brownie 450 on April 01, 2011 at 15:43:40 from (66.43.241.198):
In Reply to: digital tach again posted by timis on March 31, 2011 at 21:39:54:
Most of them have an LM317T and/ or a generic 5-volt regulator --7805. These are a 3-lead regulator with numbers on the front face.
You probably should replace the power supply input electrolytic capacitor on the board while you're into it. Should be labeled 20 to maybe 100 MFD. at 25 to 50 volts--again, locally available.
