Re: A exhaust manifold outlet threads stripped
Posted by Owen Aaland on April 01, 2011 at 17:04:57 from (216.47.32.140):
In Reply to: A exhaust manifold outlet threads stripped posted by tjiniowa on March 31, 2011 at 20:03:26:
It also helps to run the engine under load before installing the new pipe to heat the manifold. With the manifold hot and the pipe cold you can get it installed tighter.
