Re: F-12 hydraulic lift
Posted by 292 Ralph on April 01, 2011 at 22:39:32 from (75.88.26.107):
In Reply to: F-12 hydraulic lift posted by MHPull44 on April 01, 2011 at 09:00:36:
About ten years ago my M farmall was broke down about hay time.I needed a tractor to mow with and my F12 had a powerlift on it.The three point off my M bolted right to the axle clamps and with a little engineering and a hyd.valve I bolted my 501 mower to it and mowed my hay with it .Fawteen was kind enough back then to post pics for me.It will lift a 5 ft rotary mower and if anyone is interested write me and I will talk more about .It is also in tractor photos.Thanks Ralph
