Re: F-12 hydraulic lift
Posted by Fawteen on April 02, 2011 at 02:56:47 from (72.73.113.153):
In Reply to: Re: F-12 hydraulic lift posted by John M on April 01, 2011 at 18:57:14:
Ah. I remember packing up that top!
Two things occur to me about the problem:
1. Low oil. My pump leaks and over time the oil from the lift winds up in the trans.
2. Bad vane springs. The vane that moves the rockshaft fits in a slot on the shaft and the other end seals against the housing. It's held in place by spring pressure. The springs are in the slot the vane sits in, IIRC.
