Re: Spun Bearing?
Posted by Janicholson on April 02, 2011 at 13:05:14 from (67.72.98.45):
In Reply to: Re: Spun Bearing? posted by pete_5959 on April 02, 2011 at 11:43:24:
The choke plat can be seen through the intake from the air cleaner. Use a good light. The throttle plate is also screwed in place. If the throttle plate comes loose, the throttle plate will get crooked and jamb in the bore. This prevents it from closing, and with a little governor action can make it race way up in RPM. My guess is that if you find that to be the case, and you cannot see the screw with a good light in the cylinders (through the plug hole with each piston up at the top) you will be pulling the head to get the screw out. Jim
