Re: 87 octane
Posted by CNKS on April 02, 2011 at 13:51:02 from (216.144.104.128):
In Reply to: Re: 87 octane posted by CNKS on April 02, 2011 at 10:00:03:
I did a little studying on octane numbers. The M used in calculations must be at least 82, therefore the R has to be 92 for R+M/2 to equal 87. (92+82)/2 = 87. Thus todays 87 octane gas is 92 octane by the research method or a full 5 points above the 87 required in my 460 Operators manual. Should be enough.
