If I recall correctly you have to securely block the tractor up and unbolt the axle from the tub and take out the bull gear bolt. You only need to move the axle enough to slide it out of the hole in the bull gear and then roll the bull gear back or lift it out. Then you put bolts in the two threaded holes in the pinion housing on the outside of the tub and they pull the housing out of the tub. Zach
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
