Re: Super A, problem starting
Posted by gene bender on April 02, 2011 at 14:51:10 from (67.55.227.7):
In Reply to: Super A, problem starting posted by JohnKenny on April 02, 2011 at 14:41:30:
Going to 12v doesent make a tractor start. Do you have gas running out of carb when you remove the drain plug should be a steady flow. remove the spark plugs now hook up the wires going to them and make sure they are grounded now with voltage to the dist when you turn on the sw and hit the starter you should have spark on all of them. Now if you have spark is it in time that would be next6 and when thast checks out it WILL START.
