Load Checks on 1066
Posted by Michael Sheik on April 02, 2011 at 14:54:34 from (65.255.84.133):
I have problems with implements creeping down after raised. This happens on numerous cylinders and known good one. Called and talked to IH mechanic friend and he said IH sells what are called load checks that go inline on tractor remotes. I guess rig them to where they plug into your remotes and then your implement hoses plug into them. Parts man just called and said they are available and are 169.00 each and you need two. WOW! Is there any other place to get these that would be cheaper.
