Do you have a mag or a distributor? As Gene suggested you need to check for battery voltage if have a distributor. Use a volt meter or test lite if you have a distributor. With the points open you should have voltage on both small terminals on your coil. You will need the ignition switch in the on "position". No voltage there check your switch terminal that feeds voltage to your coil. You may have a bad switch, broken wire or bad connection. If you have voltage clean your points until shiny. Clean the points if you have a mag as they don't need battery voltage. Hal
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
