Posted by Roger46 on April 02, 2011 at 15:53:22 from (72.100.202.242):
In Reply to: Re: Spun Bearing? posted by pete_5959 on April 02, 2011 at 13:39:21:
The exact thing happened to me a long time ago on my dad's H. I took all the spark plugs out and brought the pistons up to TDC one at a time and looked in with a flashlight. I found the screw flattened and slightly imbedded in the piston top of one of the pistons. I used a long thin screwdriver to dislodge it from the piston, put grease on the end of the screwdriver, and lifted the screw out. By the way, this was after dropping the pan to check rod bearings and other things. Roger
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
