Re: Super C Fast Hitch Settling
Posted by achodges1 on April 02, 2011 at 16:23:09 from (66.139.216.154):
In Reply to: Super C Fast Hitch Settling posted by WI-Ed on April 01, 2011 at 18:09:08:
If we're talking about the fast hitch and not the Touch-Control it reduces the systems that can fail. The fast hitch has a control valve,a check valve and the cylinder. The control valve has no internal o-rings so it should be OK if it doesn't leak. The check valve might be the culprit but it has few internal parts, one o-ring and a check valve that was metal in mine. I think the best bet would be the cylinder. Doesn't take much trash to score the main o-ring in the piston and that can cause it to settle. If you haven't already, you need the check the screen in the touch control unit to see if it is intact. If not or if you changed it already the system might have trash in it.
