Re: Super A, problem starting
Posted by D7fever on April 02, 2011 at 16:27:52 from (74.106.76.98):
In Reply to: Super A, problem starting posted by JohnKenny on April 02, 2011 at 14:41:30:
Yep, you need 0 or 00 gauge cables, also check to see if there is a mouse nest in the flywheel housing, I have had that twice on my tractor, and once on my friends, when a mouse nest is in there, it drags it around and jams the starter gear on the flywheel, cheap easy fix. Also if your ground wire is not bolted to one of the starter bolts, you are probably not getting a good ground. But first of all, we are all assuming that your engine turns freely, hopefully we are assuming correctly.
