Re: H bull pinion bearing Removal
Posted by Janicholson on April 02, 2011 at 17:07:28 from (67.72.98.46):
In Reply to: H bull pinion bearing Removal posted by Adam C on April 02, 2011 at 14:27:04:
The idea Zachary indicates is OK but there is no need to unbolt the axle or take off the wheels. Put boards under the wheels, jack up the rear housing to take all but tire/wheel weight off of the tires. Remove the outer axle bearing seal retainer and the bull gear retainer bolt in the center of the bull gear. I put shims under the bull gear to keep it up in the air. Then the axles wheels and tires can be scooted out far enough to get the bull gear back out of the way of the pinion cage. Be careful with blocking to assure safety. Jim
