Re: Super A, problem starting
Posted by CNKS on April 02, 2011 at 18:00:15 from (216.144.104.128):
In Reply to: Super A, problem starting posted by JohnKenny on April 02, 2011 at 14:41:30:
2 gauge is plenty for that tractor, good connections are more important than gauge. Many on this forum seems to be stuck on 0 or 00, which I have never even seen, much less used. None of my 6 volt tractors (5) have any bigger than 2 gauge. If you suspect the switch, take it out and look at it. Mine had a loose wire that I found after checking everything else. Warning sign was trying to cut out occasionally while running. I should have checked that first.
