Re: Governor Linkage Moves on 1 side but not the other..??
Posted by Bob on April 02, 2011 at 22:16:26 from (64.255.159.192):
In Reply to: Governor Linkage Moves on 1 side but not the other..?? posted by AL Farmall Boy on April 02, 2011 at 21:18:15:
The spring inside the governor fights the action of the weights to control speed. Without the engine running, half of this equation is missing... the action of the weights that tends to close the butterfly as engine speed increases.
For someone familiar with setting up the linkage or verifying if the governor is functioning, it would take FAR less time "hands on" than to try to explain the whole procedure in writing.
BEFORE buying parts or tearing into anything, have a knowledgeable person check it out or obtain a copy of a shop manual and begin by following the procedure to set up the linkage between the governor and the carburetor.
