Re: Adding Deluxe cab to 766
Posted by Allan In NE on April 03, 2011 at 02:04:07 from (148.66.88.254):
In Reply to: Adding Deluxe cab to 766 posted by pudamobile on April 02, 2011 at 19:13:37:
Assuming the cab has the "pivots" at the rear axle mounts, you can roll the thing onto the tractor all by yourself in 10 minutes with just the aid of a come-along and a handyman jack.
That's the easy part.
Getting the tractor ready before-hand is the hard part. Lots and lots of parts have to be installed/interchanged first:
Fenders removed
Dash electrical wiring loom and cab power relay
Tool box removal
Battery boxes
Front cab support irons
Lower cowl pieces
PTO shifter
Floor board
Clutch and brake pedal boots
Air conditioning compressor and hoses
Heater hoses
Exhaust extension
And most importantly, the sound deadening material. If you don't redo the inside of the cab and properly deaden the tractor cowl area, you'll hate every minute you have to spend inside that tractor.
If you need pictures, hollar back.
Allan
