Posted by El Toro on April 03, 2011 at 04:08:10 from (108.3.156.106):
In Reply to: 560 Dies posted by redtailwis on April 02, 2011 at 19:53:01:
Disconnect the gas line at the carburetor and see if you have a full stream of gas from the tank. Use a clean container to catch the gas.
If there's just a trickle of gas you need to clean the gas tank. If you have a full stream of gas remove the gas fitting where your gas line connects and look for a screen behind that fitting. It be could full of dirt or rust. If the screen is clear of any dirt your carburetor probably needs a good soaking in carb cleaner and a good cleaning. Blow out all the jets with compressed air. If that carb has a solenoid at the carb inlet it may not be opening fully. Hal
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
