Farmall super c - cam gear governor gear timing que...
Posted by brumik on April 03, 2011 at 07:14:21 from (67.142.165.28):
I replaced a bad Cam Gear on my super c.
I've got the punch marks meshed up on the crank and cam gears.
Do i need to also do the same with the governor gear?
I actually don"t think the governor gear was in mesh with tick mars when i took it apart. I think it was about one third way around the gear approximately.
I've got a 12 volt system with distributor - if this matters at all.
Any advice is appreciated.
Bruce
