Re: Is I H 1586 a good model?
Posted by scotc on April 03, 2011 at 09:41:39 from (72.100.78.252):
In Reply to: Re: Is I H 1586 a good model? posted by MARKS87 on April 02, 2011 at 03:07:18:
The 1566 had a DT436, I'd guess the 1586 did too. The gears are helical cut in the 15's instead of straight cut like in the smaller models. They also don't slide the gears, they have a synchronizer-type set-up, a coller slides over a set of dogs on the gears to engage them. A wider collar on the 2nd gear would help a 1566, as it was hard to find 2nd sometimes. I don't know if a 1586 uses the same part or not.
They are not a good haying tractor. The step from 1st to 2nd gear is bigger than the 4 speed tractors. If you run a diskbine with it you can easily be too fast or too slow. They are good for the chopper but that's the only thing we did with ours besides tillage.
