Re: Farmall h starting problem again
Posted by gene bender on April 03, 2011 at 13:47:59 from (67.55.227.7):
In Reply to: Re: Farmall h starting problem again posted by farmallboy15 on April 03, 2011 at 09:49:08:
You need a sw to turn it on and off.How many volts are you getting to the coil. Do you have a mag with a mounted coil outside or do you have a dist either case you do need the sw to turn the voltage on and off.
