Re: Super A, problem starting
Posted by Janicholson on April 03, 2011 at 16:09:54 from (64.61.211.87):
In Reply to: Re: Super A, problem starting posted by JohnKenny on April 03, 2011 at 15:04:56:
There is a heavy (10ga) wire from the starting switch going to the amp meter. From the amp meter other terminal there should be one wire going to the voltage regulator on the generator.
Another wire going to the light switch (or fuse hopefully) then to light switch.
because it has a mag no other wire should be connected. Use a test light to make sure these are as described and have voltage at all times.
Any disconnect is wrong, these terminals and wires are to be hot at all times, running or not. Jim
