It is practically impossible for the crankcase to fill with gas from a stuck float.
First off, the carb is an UPDRAFT. It is positioned BELOW the intake manifold.
The carburetor and the manifold would have to completely fill with gasoline before any started running into the cylinder. If that were the case, it would be so flooded that it would never start. It would hydrolock on the first crank over.
Second off, there is a drain on the carburetor that lets the gas run on the ground if the carburetor floods. That would have to be plugged before the gas would start filling the manifold.
Third off, the air intake isn't always a perfect seal. Gas would run out around the hoses even if the carburetor drain is plugged.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
