Posted by Jim Becker on April 04, 2011 at 07:56:08 from (173.57.163.253):
In Reply to: Super A hydraulics posted by drmiller on April 04, 2011 at 07:27:17:
Assuming you are dealing with the regular rear rockshaft and the Touch-Control, you should be able to change it in about 10 seconds with one wrench. The lift rod that runs back from the Touch-Control arm to the rear rockshaft should be similar to what NawlensGator described. Add one more detail, the lift rod should have a set collar at the front end of the sleeve. Loosen the set collar and slide it forward so it doesn't touch the sleeve when the lift is lowered. If NawlensGator slides his collar the other way, he will get down pressure.
If this doesn't apply, you must have something different and will need to post a picture of what you have.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
