Re: Re: Re: Re: Re: Water in Oil
Posted by dave on July 24, 2000 at 19:05:57 from (205.242.56.60):
In Reply to: Re: Re: Re: Re: Water in Oil posted by Andy on July 24, 2000 at 16:36:01:
pull the oil pan,pull the spark plugs out.then go get yourself a cooling system pressure checker,or make your own with an air commpressor.you will have to make a fitting to go on the block,or make a hose adapter.don,t go over 5psi when you pressurize the system.once you do that you should be able to look up into the engine block to see what is leaking.same for the sparkplugs,if leaking in the comd. chamber you should be able to see or hear it.
Post A Followup
: Re: Re: Re: Re: Re: Re: Water in Oil
