I would not expect this part to be available at your local CaseIH dealer. You will probably need to salvage it off another 460 Utility that has the delete shaft.
The TA in your tractor is probably the original. That means it's lasted for about 50 years.
The tractor's "busy years" are long behind it. There's no way you'll ever use the tractor as much as it was designed to be used.
Get the TA fixed, adjust it once in a while, and it will outlast you. When it's working properly, you'll really come to appreciate it.
If you really really insist, you can remove the access cover and weld up the planetary gears. That will permanently disable the TA, essentially making it a TA delete.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
