Re: How to remove PTO seals on H
Posted by neblinc on April 04, 2011 at 17:43:55 from (98.16.147.142):
In Reply to: How to remove PTO seals on H posted by Farmallb on April 04, 2011 at 14:35:14:
If they are the original leather 1 inch seals they could be rusted to the side of the casting.
Take your time, add some heat and it should peel out of there. Try and collapse the seal inward with a chisel being careful not to gouge the casting.
I have had some nasty upper bolster seals that I have had to torch out.
Randy
