Re: '46 H Stuck in Gear
Posted by S-E Michigan Part Timer on July 24, 2000 at 20:26:26 from (208.223.205.166):
In Reply to: '46 H Stuck in Gear posted by Bill White on July 24, 2000 at 19:00:08:
I've heard of this before, and did do it once to an M. I guess some can actually get stuck in two gears at once. Now that you've tried to move it, two different gear sets w/ different ratio's are fighting against each other, causing a pretty good bind you notice in the shifter. Supposedly, if you rock the tractor back and forth by the rear wheel, you can get it back into neutral. Not sure how hard you'll have to rock this one, may need two of you.
Post A Followup
: Re: Re: '46 H Stuck in Gear
