Definitely do NOT weld the cam shaft unless you want to purchase a replacement shortly afterward. It will cause heat stresses. Not sure about the amount of float in the shaft, but it does not sound usual to me. Generally cam gears just slide on without too much trouble. Check for any burring on the cam shaft and on the inside of the gear wheel. These must be absolutely clean. The slightest burr can cause the gear to jam. If it is an interference fit, then you will have to heat the entire gear to fit it. Hot oil works well, but be careful not to start a fire.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
