Re: '46 H Stuck in Gear
Posted by Jim on July 24, 2000 at 21:54:58 from (199.240.128.82):
In Reply to: '46 H Stuck in Gear posted by Bill White on July 24, 2000 at 19:00:08:
The way you get the transmision out of gear is to drive the pin out of the shifting lever and then you take the lever out and line up the shifting forks. To help prevent the problem of sticking in gear you should get the shifting lever built up so it don't jump out of the rails. To build up the lever you need to weld up the bottom and square up the sides.
Post A Followup
: Re: Re: '46 H Stuck in Gear
