Re: IAC 300 Utility Tractor
Posted by Chas Weller on April 05, 2011 at 05:23:07 from (71.245.10.101):
In Reply to: Re: IAC 300 Utility Tractor posted by Trucker101 on April 04, 2011 at 20:25:23:
Cam, Crank, valve timing will not be affected by
removing the pump and gear - when all reassembled
you must set the distributor timing. This I think
is easiest to do by marking top dead center before
removing the distributor, use timing mark on crank
pulley - when it is TDC the rotor under
distributor cap will point to number one cylinder
plug wire when cap is installed on distributor.
Sometimes you will find that parts are already
marked; the cap may have something to show #1
spark plug wire and the metal distributor case may
have a small grove scratched or cut to show where
the rotor points for #1. Mark these positions for
an easy way to re-time the distributor. When you
are ready to reassemble be sure the crank pulley
is aligned with the TDC point, then install
distributor with rotor pointing to the mark you
made on the case of the distributor. Most
important I think have a repair manual; Always
best not to rely on memory and my typing. With my
IH 300U I continue to have hydraulic issues, it
seems that I can never get everything working
exactly right?
