Re: IH Wide Front
Posted by Allan In NE on April 05, 2011 at 06:08:55 from (148.66.88.254):
In Reply to: IH Wide Front posted by nates90 on April 05, 2011 at 05:25:29:
Oh yeah,
Like Gary says it will strap right on there.
The camber geometry is a little off and it won't turn near as sharp as the original small frame wide front tho.
You can go up in the bolster on both sides with a little hand-held chop saw and narrow up those block stops, but it still will not be quite right.
First picture is the 806 front at full stop, the second picture is after I chopped the stops. Third picture is the proper front end. Notice that camber change?
Finally I just couldn't stand it anymore, gave up and swapped it out for a small frame front end, as I use the tractor is small areas and need it to spin around on a dime. That camber change made all the difference in the world when it came to spinnin' 'er around. :>)
Allan
third party image
third party image
third party image
