Re: B414 glow plugsSTILL NO GO
Posted by Heat Houser on April 05, 2011 at 09:23:09 from (69.66.35.73):
In Reply to: B414 glow plugsSTILL NO GO posted by Fordman6442 on April 05, 2011 at 07:03:18:
Well, this is just memory from many years ago on a BD144 in a TD5 and I reserve the right to be wrong.
The indicator and glow plugs were in series and were what I will call a "balanced" system. You need all 5 resistances in series (the indicator and the 4 glow plugs) or you will burn one out.
The indicator should reasonably indicate how hot the plugs are by the color of the element. If you are white hot, your resistances are not correct. Do you have a glow plug shorted? Are all of the correct resistance?
The glow plugs and indicator will be rather low resistance but grab your meter and ohm each one indivdually. Compare the readings to see if one is way out of range with the others.
The other way to do it is to compare voltage drops across each plug (including the indicator as it is a seperate resistance). While heating, put your meter leads, one on the input wire to the plug and one on the output. Read the volts doing the same to each. All should be approx the same reading.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
