Re: IH 460 utility TA Delete
Posted by pete 23 on April 05, 2011 at 10:42:32 from (74.44.100.190):
In Reply to: IH 460 utility TA Delete posted by Mark Albers on April 04, 2011 at 08:50:07:
Here is something else I have done to one 560 and it worked out ok. I gave it a single split between ta housing and rear housing. Then pulled the output shaft out of the ta and discarded the rollers from the ramp. You can easily put the out put shaft back in again with out the rollers. What cannot be done is to replace the rollers doing it that way and that is why you have to do a two split, complete tear down to replace the ramp and rollers. By leaving the rollers out you solve rollback problem, use direct drive only and shift easy. .
