I had problems with my F504 binding in gear when stopped. I found my linkages were out of adjustment. After I worked with my adjustments and got both clutches set it works fine.
I use my TA more as a split axle than a power booster. Meaning if I'm bush hogging I use it to slow down in rough spots and in turns. Originally they were designed to give a lower gear for heavy draft loads (plow, disk, ect) In normal use we will never put that kind of load on a TA, especially not on a daily basis.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
