Re: Super C Cam Gear installation
Posted by El Toro on April 05, 2011 at 14:37:04 from (108.3.156.106):
In Reply to: Re: Super C Cam Gear installation posted by brumik on April 05, 2011 at 13:21:18:
See if you can block off the lower outlet on your engine and fill the engine w/water then see if any water is leaking around the bell housing. If any water is leaking then you know the engine needs to be pulled. You need to support that tractor from tilting backwards when you remove the engine. You need to use a suitable crane or hoist & slings to handle the weight of that engine. Be careful. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
