I am going to post this link to see the page out of the manual. If you read and look at the picture you can see that unless the adjustable collar is set to push the limit stop the hitch will let down even with the motor running. The limit stop stops the flow of oil with or without the motor running. To release the limit stop all you do is push the remote valve to raise the cylinder and the limit stop pops out.
I was super confused until I read that. I could hook to my blade, put a pin through the lift rod, and lift the rear wheels off the ground. I could set the collar to push the limit stop and the rear wheels would still be off the ground in the morning.
If I were the OP I would try this if he has not tried it. If the limit stop is pushed down and the lift lets down, then replace the O-rings in the FH cylinder Including the limit stop. That little O-ring on the limit stop could also be the only problem, or just one of the problems. Replacing the O-rings in the cylinder is very easy and not expensive. But i am no expert and the info is worth what you paid for it.
My Dad had a lot of tractors that I didn't get. The A was his last tractor at the house when he died. I will miss the tractors but my wife is a good wife and a nice lady. She doesn't like tractors. I don't like shopping, baby showers and weddings. That doesn't make me a bad guy. Ron
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
