Re: Broken fan bracket - Need part or information
Posted by nosih on April 05, 2011 at 18:05:51 from (64.198.192.11):
In Reply to: Broken fan bracket - Need part or information posted by Ricky Williams on April 05, 2011 at 08:49:40:
I have a NOS front cover available if you decide you want to replace it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
