Posted by Bob M on April 05, 2011 at 19:15:23 from (67.240.171.41):
In Reply to: H steering problem? posted by pintobill on April 05, 2011 at 18:29:17:
If memory serves the special, extended stop bolt goes in the right front flange hole. You can tell for sure by peeking at the underside of the upper bolster casting. There will be a crescent-shaped slot for the stop bolt head fit into.
Using a longer bolt installed upside down will probably work. You might want to slip a piece of soft copper tubing or similar over the exposed threads however. Otherwise the bolt threads are likely to become boogered after a while making it hard to remove later.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
