Re: amp gauge
Posted by Harold Evans on April 05, 2011 at 22:10:16 from (69.136.4.122):
In Reply to: amp gauge posted by 41farmallb on April 05, 2011 at 18:43:30:
If you want to read volts, just add a volt meter. They're the easiest to wire. Just attach one wire to hot and the other to ground, preferably after the ignition switch so that you won't drain the battery while the tractor is parked.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
