Re: IH 460 utility TA Delete
Posted by mkirsch on April 06, 2011 at 05:19:16 from (64.80.110.75):
In Reply to: IH 460 utility TA Delete posted by Mark Albers on April 04, 2011 at 08:50:07:
Before you get all hot-and-bothered about installing a "TA elimination kit" or welding up the gears, figure out why the clutch isn't releasing.
Welding the gears won't fix the problem you're having right now.
Either the linkage is totally out of adjustment, or there is something broke in the TA clutch.
Fix the TA clutch, and your TA will probably work just fine, judging by its current behavior.
