Re: C-Fast idle problems
Posted by FC Andy on April 06, 2011 at 06:41:55 from (96.230.233.211):
In Reply to: C-Fast idle problems posted by MK in Ontario on April 06, 2011 at 06:24:05:
Well, I think you may be on to something with your plug wires. In a direction at least. And yes, if the distrubutor cap on your mag is bad, it can have the same results. While you're there, don't forget points and condensor.
Just for S+G, are you quite sure that it isn't running lean?
Good luck, Andy
