Re: Eliminating Sediment Bowl
Posted by John M on April 06, 2011 at 18:21:27 from (67.231.169.173):
In Reply to: Eliminating Sediment Bowl posted by Dellbertt on April 06, 2011 at 17:32:55:
Get ready for the flames! They are coming. I put a brass elbow and shutoff, connected to the carb via a rubber hose with an inline filter I got from Napa, and it has been runing that way for well over 15 years.the filter has been changed a couple of times, and the last one is a se-through deal that you change the guts in. The key is to get a filter that will work in a gravity flow system.
