Re: Where to find the flexible wire conduit for rear light?
Posted by jeffkoh on April 06, 2011 at 18:22:51 from (24.144.153.146):
In Reply to: Where to find the flexible wire conduit for rear light? posted by Yooper Farmall on April 06, 2011 at 09:23:46:
you are looking for 3/8 flex or super flex. any electrical supply house should have it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
