Re: farmall 400 power steering problem
Posted by Nebraska Kirk on April 06, 2011 at 20:58:20 from (207.91.4.197):
In Reply to: farmall 400 power steering problem posted by Aaron Brown on April 06, 2011 at 20:36:53:
The flow divider valve is the most likely culprit.
My 400 had the same symptoms as yours does. After using it for awhile the power steering started working like it should, probably some crud in the valve that just needed some time to work loose.
You can try taking the valve apart to clean and check it out or you can get a rebuilt flow divider valve from steelwheelranch.com
This post was edited by Nebraska Kirk at 20:59:10 04/06/11.
