To look at this logically, the main thing that would cause this problem is a lack of spark. This could be traced to bad plugs, wires, distributor cap, etc. I also suppose there could be some internal problem causing this failure. The thing to do would be to pull your plugs, make sure they are not cracked or are discolored bad. Then make sure your plug wires are good. If all of this checks out, get into the distributor and make sure everything is functioning correctly (for example, rotor button, points, etc.). If the tractor is in good condition otherwise, you will most likely find a problem with one of these components. Good luck, SF
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
