Re: farmall C hyd pump
Posted by gene bender on April 07, 2011 at 04:06:37 from (67.55.227.7):
In Reply to: farmall C hyd pump posted by Jim Alvey on April 06, 2011 at 17:43:18:
Two seals were used you will need to remove your pump to find out which one you need and then go from there if the journal is worn you will need a speedy sleeve or the new seal wont last.
