OK Boys...I need Help..lol
Posted by MF1155 on April 07, 2011 at 07:02:43 from (64.12.116.73):
I just posted in tractor talk as well. I got a customer with a 434 gasser, the carb was junk. I put an economy kit in it and it is either fooding then I bent retaining flap a pinch ..now too lean. The problem is the float has a nasty dent to it from freezing, and the float flap is severly worn. The float assembly is not available from Case IH. Its part number 3047463R91, it fit other models as well, 276,354,434,444,B414. Do you guys know wher to get one of these Zenith VNN downdraft float assemblies??? Thanks
