Re: Eliminating Sediment Bowl
Posted by NawlensGator on April 07, 2011 at 08:48:21 from (52.129.12.50):
In Reply to: Eliminating Sediment Bowl posted by Dellbertt on April 06, 2011 at 17:32:55:
What is it with the sediment bowls? I have 3 tractors with them and none leak. I use the rubber gaskets and brass screens from the IH dealer. I usually clean each one out every yr or two and keep everything tight. I like the glass bowls because they allow you to keep water out. Filters produce pressure drop to in already marginal system.
